1997 Plymouth Breeze tierod
1997 PLYMOUTH BREEZE
86,524 MILES • 4 CYL • FWD • AUTOMATIC
DBILLINGS68
i was wondering if you could give me information on how to install an tie rod on the front drivers side of my plymouth breeze. i need step by step instructions and how to get the old one off
May 11, 2009 at 2:42 PM
BMRFIXIT
  • 19,053 POSTS
tie rod
is it the inner or the outer
outer tie rod
jack and support the car
remove tire
loosen lock nut on the inner and outer tie rod
remove hold down nut
remove tie rod from knuckle
turn loose tie rod and remove
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 11, 2009 at 3:14 PM
