1997 Plymouth Breeze Slow Cranking
95,000 MILES • 4 CYL • FWD • AUTOMATIC
HANSEN503
I recieved a 97 Plymouth Breeze from a friend for my son. I cannot get the car to start. I have replaced the battery and the starter. I have read some of the other slow cranking posts and some may be helpful, but have not been direct enough.
I am wondering if I need to take a look at the timing belt and both the CamShaft and Crankshaft position sensors? I have also seen a post or two saying that there may be issues with the alternator. I am trying to teach my son car repair and car care so he can be a little more self sufficiant. I however happen to be stumped.
I also know I have a head gasket leak and a valve cover gasket leak in the rear of the #2 and #3 cylinders....gasket replacement I get.....electrical issues I am having a hard time with at this point.
We won't get in to the massive issues suspension issues I will have to deal with with the ball joint...
thanks in advance.
Dave
Aug 9, 2010 at 3:48 PM
  • 75,988 POSTS
Try turning the crankshaft 720degs if its hard to turn
Could be hydro locking on those cylinders inspect the cylinders for coolant causing it to crank slow
Might be the alternator not producing the correct voltages or something is eating up the battery overnite causing it to be low-
Aug 9, 2010 at 9:00 PM
