1997 Plymouth Breeze rear braked
122,000 MILES • 4 CYL • FWD • AUTOMATIC
LARWINN
i replaced the rear brakes. I had a really hard time getting the drum back on over the new brakes... very tight fitting. The cylinder was retracted. After test driving, the wheel got really hot. I don' t think the pads are "moving" properly.
Thanks for your help.
Jul 19, 2008 at 5:46 AM
DOCFIXIT
  • 18,828 POSTS
Did you retract the star self adjuster?
Jul 19, 2008 at 6:08 AM
LARWINN
Yes, I did retract the star - The plungers in the cylinder were complete retracted as well.
I tried to drive the car a little way..... "smoke"!!!!
Jul 19, 2008 at 8:50 AM
DOCFIXIT
  • 18,828 POSTS
Try backing off on the parking brake adj.
Jul 19, 2008 at 8:53 AM
LARWINN
I don't know how I would do that - it's just a cable connected on the bottom of the shoe.
Jul 19, 2008 at 8:58 AM
DOCFIXIT
  • 18,828 POSTS
Follow both cables up toward the brake lever you will see a threaded bod a nut back it offtill there is slack in cables. If that frees up then Adj by pulling lever 5 to 7 clicks tighten to hold car from rolling.
Jul 20, 2008 at 9:26 AM
