Transmission problem
1997 Plymouth Breeze Front Wheel Drive Automatic
I was driving my Breeze 97 the other day and the engine light came on and it felt like the transmission wouldn't switch gears. I was able to drive at the speed of 50 km and the engine was running at 3000 rpm. Plugged it to my obd ii computer and the code P0700, 1776 came up. I added some transmission fluid and erased the code and after that it ran fine. The car has been leaking transmission fluid for a while so I have been adding tmf regularly but it has always worked fine.
What causes the transmission to act like that?
Why does it run fine after I erased the codes?
What needs to be repaired?
Is it ok to keep on driving my car?
kind regards from Iceland
Sep 7, 2009 at 6:52 AM
