1997 Plymouth Breeze no spark
123,000 MILES • 4 CYL • FWD • AUTOMATIC
KSEABYTHEC
My car will crank, but gets no spark to any of the plugs. Ran fine yesterday morning, started having trouble in the afternoon and dead this morning. Any suggestions? Just replaced all the plugs two weeks ago. Thanks in advance.
Nov 19, 2008 at 12:34 AM
BMRFIXIT
  • 19,053 POSTS
1.check the timing belt and make sure cam shaft is spinning when engine cranking
2.check fuses and relays (ASD relay)
3.check ignition coil
4. scan for codes cycle key on of on off on (check engine will flash codes and or read P codes in the odometer area
5.check crank sensor
let me know
Nov 19, 2008 at 8:46 AM
