1997 Plymouth Breeze how many quarts
83,500 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNNYBOY101289
how many quarts does the automatic transmission in a 1997 plymouth breeze take and also i have a leak coming from somewhere near the rear main gasket in the trans whut could that possible be ???
Apr 17, 2009 at 12:38 AM
  • 110,248 POSTS
If you only drained the pan and replaced the filter, you only removed about 4 quarts. As far as the trans leak where it connects to the engine, there is a front seal on the trans that can leak.
May 10, 2009 at 1:25 PM
