1997 Plymouth Breeze Hesitates
1997 PLYMOUTH BREEZE
185,000 MILES • 4 CYL • FWD • AUTOMATIC
RACHELLYNN1986
When I take off my car spits like its not getting enough gas or losing power.. What could the problem be???
Aug 23, 2009 at 1:20 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 23, 2009 at 7:43 PM
