1997 Plymouth Breeze heating up using water
1997 PLYMOUTH BREEZE
158,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOYOTA789
would you have any idea why this car is getting hot an needing fluid in the radiator almost every time it is driven?
also do you have any idea why this car has problems going up slopes no power ?
thank you
Aug 16, 2009 at 9:15 AM
SERVICE WRITER
  • 9,123 POSTS
The liquid in the radiator must be a 50/50 mix of antifreeze and water or it will not cool properly. This may have caused engine damage and causing the second problem.
IF the system is not holding antifreeze then first check the oil to see if it looks abnormal. If okay,Then pressure test the cooling system for a leak.
Aug 26, 2009 at 12:17 AM
