1997 Plymouth Breeze Engine Or Transmission? Spark Plug Oil
1997 PLYMOUTH BREEZE
CNVH
Engine Mechanical problem
1997 Plymouth Breeze 6 cyl Two Wheel Drive Automatic 150k miles
Ok, so we now have two down cars.....
Our 1997 Plymouth Breeze was doing funny things mostly since we acquired it alittle over 2mo. ago.
Supposedly the tranny had been replaced, but idk for sure....
We replaced the speed sensor, then the radiator started making "draining" sounds....the hubby discovered it needed a new radiator cap and replaced it, but the car is running so roughly that everytime you stop it wants to die and you must put it in N and keep your foot on the gas just to keep it going and then when my hubby checked spark plugs the other day he said they were wet with oil and he doesn't know why.
......so what's it's problem?
Sep 12, 2008 at 3:05 AM
THOMAS29
  • 6 POSTS
mine did this too. had lost of oil where the spark plugs go. we replaced the valve cover gasget and its all better
Dec 6, 2008 at 9:50 AM
