1997 Plymouth Breeze belt
1997 PLYMOUTH BREEZE
WESLEY2147
Engine Mechanical problem
1997 Plymouth Breeze 4 cyl Automatic 143000 miles
What is the tention on the rib belt on the alternator and could you please show a diagram of it? Thank You.
Dale
Oct 4, 2010 at 4:51 PM
  • 31,937 POSTS
Hi there,
The only tension given is that with a belt tension gauge, but if you tighten the belt so it has about 5-8mm deflection at the longest free length that should be ok.
Mark (mhpautos)
Oct 4, 2010 at 9:03 PM
