1997 Plymouth Breeze alternator not charging
65,000 MILES • 4 CYL • FWD • AUTOMATIC
RYANB71
i have a 97 plymouth breeze and i put another motor in it and when i got done putting it and stuff i went to start it and the battery light came on so i thought i was from disconnecting the battery and all but it wasnt so i took the alternator out and put another one in and it still did the same. so is there anyway i would jump wires from the alternator to make it charge thanks
Dec 5, 2007 at 12:56 PM
BMRFIXIT
  • 19,053 POSTS
[quote:063bc744d6="ryanb71"]Electrical problem
1997 Plymouth Breeze 4 cyl Front Wheel Drive Automatic 65000 miles
i have a 97 plymouth breeze and i put another motor in it and when i got done putting it and stuff i went to start it and the battery light came on so i thought i was from disconnecting the battery and all but it wasnt so i took the alternator out and put another one in and it still did the same. so is there anyway i would jump wires from the alternator to make it charge thanks[/quote:063bc744d6]
check fuse s
check the wires at the back of the alternator
should have battery volts at the big one
Dec 16, 2007 at 6:32 AM
