1997 Plymouth Breeze
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
BARNETTMORGAN
I have no idea about cars but my brake lights aren't working they stay on while the car i on and they don't go off till i take the fuse out. I changed the brake light switch and i'm still having the same problem. When I put a fuse in slot 7 and turn the lights on the fuse blows. Please help!!!!!!
Sep 1, 2010 at 12:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuse # 7 (20 amp) is for the headlight and instrument cluster circuit. since it blows as soon as it's replaced, most likely the headlight switch is faulty and needs replaced which is also what is causing the brakelight issues. first check the wiring for the headlight switch to ensure wiring is not damaged or loose.
Sep 1, 2010 at 1:12 PM
