1996 Plymouth Breeze trans fluid leak
187,000 MILES • 4 CYL • FWD • AUTOMATIC
HATHCOCKJOHN
can you remove the drive shaft passenger side to replace the output shaft seal without taking loose the strut
Nov 11, 2009 at 8:53 AM
  • 110,246 POSTS
It needs to be disconnected at the bottom so you can remove the axle.
Dec 19, 2009 at 5:15 PM
