1996 Plymouth Breeze Starter
1996 PLYMOUTH BREEZE
150,000 MILES • 4 CYL • FWD • AUTOMATIC
NICK488760
I am trying to replace the starter on my Plymouth Breeze. Is there any way to remove the top bolt without having to remove the entire air intake manfold to get to it?
Oct 17, 2008 at 7:30 AM
ZACKMAN
  • 4,202 POSTS
You don't have to remove the manifold. You do have to remove the air intake assembly and move the Transmission Control Module (TCM) out of the way. DO not disconnect the harness from the TCM. Once the module moved, you should be able to see the bolt.
Oct 19, 2008 at 2:01 PM
