THIS CAR HAS A OIL LEAK ON THE TOP REAR OF ENGINE THOUGHT IT WAS VALVE GASKET CHANGED
THE GASKET BUT STILL LEAKS THE SAME ABOUT A QUART A 1OO MILES .ENGINE WET JUST BELOW VALVE COVER AREA IN REAR IS THERE A SENSOR BACK THERE CAN'T REALLY SEE WHERE THE OIL IS COMING FROM MATBE A HEAD GASKET WHAT IS YOUR BEST GUESS .THE CHECK ENGINE LIGHTS OR CODES ARE NOT ON. BUT THE UNDECARRAGE AND REAR ENGINE ARE SOAKED
THANKS
ED
THANKS
ED
Mar 30, 2008 at 4:51 AM
