1996 Plymouth Breeze Front oil seal
MYSTICSTORM
Engine Mechanical problem
1996 Plymouth Breeze 4 cyl Front Wheel Drive Automatic
What do you have to do to repair the front oil seal on a front wheel drive 1996 plymouth breeze?
Apr 24, 2008 at 3:48 PM
BMRFIXIT
  • 19,053 POSTS
replacing engine front oil seal
you need to remove timing belt to do so
Apr 26, 2008 at 11:13 AM
MYSTICSTORM
Ok might sound stupid *i'm female* anyways, so if removing the timing belt is all that is needed, I won't have to have the engine pulled out then right? I only asked because the place where I get my oil changes done at told me the whole engine had to be pulled out in order to fix it, so was just wondering.
Apr 27, 2008 at 2:09 PM
BMRFIXIT
  • 19,053 POSTS
to remove front oil seal no need for engine to be pulled out
rear main seal then you have to pull engine or tranny out
get another opinion let some body else give it a check for you
Apr 27, 2008 at 10:48 PM
