Sudden battery drain
1991 PLYMOUTH ACCLAIM
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTT BRUEHAHN JR.
My car was working fine one day, than the next day the battery was dead. I jumped it and the car started to shake like none other and and if I put it in reverse or drive it shuts off.
Jul 18, 2019 at 5:54 AM
Good afternoon,
You have low voltage from the battery being dead.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
You need to start by charging the battery to full charge. A jump will not do it. Then check the charging system to be sure the alternator is working.
Beyond that, you may have a draw that is pulling down the battery. I will attach a guide for you to follow for that.
https://www.2carpros.com/articles/car-battery-dead-overnight
Jul 18, 2019 at 6:14 AM
