How do I replace the horn? The fuse and relay are functioning.
Apr 23, 2008 at 3:16 AM
✓Experienced Mechanic
Hi: The horn should be located near the lower side of the radiator. There should be one bolt holding it on. Unbolt it, and remove the wiring. Replace it in the reverse order.
Oct 19, 2008 at 10:59 AM
VIPERTEK
MEMBER
you can test horns. is air bag light on ? horn runs thru the clockspring .
