1995 Plymouth Acclaim belt tensioner
1995 PLYMOUTH ACCLAIM
183,000 MILES • 6 CYL • FWD • AUTOMATIC
PLYMOUTH19952009
  • 8 POSTS
I need to replace the belt tensioner. How do I get the old one off? The new one just has a long screw on the back--does it just screw into the block and does the old one just rotate off?The repair manual says little but mentions mounting bolts but i sure do not see any mounting bolts.Thanks.
May 17, 2009 at 7:17 AM
2CARPRO JACK
  • 11,533 POSTS
You will need to raise and support the car.Look up from underneath the car, there is a nut holding the tensioner onto the accessory bracket.It is by the power steering pump.
May 18, 2009 at 1:12 AM
