1994 Plymouth Acclaim water pump
66,625 MILES • 6 CYL • FWD • AUTOMATIC
BMCKENZIE99
I have replaced almost everything on my acclaim that has to do with the enginge cooling system myself recently my overflow cracked so I fixed that as well but it still is overheating when drove a short distance the only thing left is the water pump...correct and where is it located and is it a job for a diy mechanic
Sep 10, 2008 at 5:53 AM
  • 110,248 POSTS
Hi:
Have you checked or completed the following?
1- rod out the radiator
2- check cooling fan operation
3- replace both upper and lower rad hoses
Any of the three could cause overheating. Let me know what you hav done so far.
Oct 8, 2008 at 11:23 AM
