1994 Plymouth Acclaim Valve Cover Gasket Torque Spec's
136,000 MILES • 4 CYL • FWD • AUTOMATIC
MGRJEBBO
I need the Valve cover gasket Torque Specs for a 1994 plymouth acclaim 4cyl. Also does that have the tin valve cover because i am worried i might have to bend it back to shape since I believe it was over tightened when the gasket was replaced last, and that is what has caused this leak.
Thank you
Aug 11, 2009 at 1:08 PM
  • 110,248 POSTS
Yes, I recommend you pean the bolt holes in the opposite direction. Also, what type of gasket are you using? If it is cork, chances are you will overtighten it again and it will leak. Try to get a composite gasket. Also, stay away from all rubber.
Sep 25, 2009 at 3:27 AM
