Yes, I recommend you pean the bolt holes in the opposite direction. Also, what type of gasket are you using? If it is cork, chances are you will overtighten it again and it will leak. Try to get a composite gasket. Also, stay away from all rubber.
Friday, September 25th, 2009 AT 10:27 AM
