1994 Plymouth Acclaim more noises
143,000 MILES • 4 CYL • FWD • AUTOMATIC
89BLUEDEMON
The engine on my 94 plymouth acclaim makes a horrendous knocking sound when you hit the accelerator. I have checked the compression,timing, valvetrain, timing belt and exhaust system. Nothing wrong there. But the noise is silent at idle. Also it makes a knocking sensation in the steering wheel at the same time. Any ideas??
Jan 12, 2010 at 1:04 PM
CARADIODOC
  • 34,413 POSTS
How about a cracked flex plate? You have to unbolt it from the crankshaft to look under the little plate under the bolt heads.
caradiodoc
Jan 12, 2010 at 6:46 PM
89BLUEDEMON
well when i installed the transmission a few weeks ago i inspected the flex plate pretty well. the knocking was going on a while before i replaced the transmission.
Jan 12, 2010 at 11:01 PM
