1994 Plymouth Acclaim rear brake lights
1994 PLYMOUTH ACCLAIM
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
GROGG1980
the rear brake lights and turn siginals dont work at all om my car i have checked the fuse and the wirring harnes
Dec 5, 2008 at 11:27 AM
If the high mounted brake light works -do below
Check fuse no. 19 10amp and fuse no.16 20amp if both okay your problem is coming from the multi function switch.
Dec 5, 2008 at 11:54 AM
