1994 Plymouth Acclaim No Power to Fuel Pump
1994 PLYMOUTH ACCLAIM
175,000 MILES • 4 CYL • FWD • AUTOMATIC
ECLIPTIK0911
I had this car running about a month ago, right after I changed the alternator belt....used an old battery to jump start it....let it run for about an hour, shut it off...and have not been able to start it since...I replaced the MAP sensor and Fuel Pump Relay....there is a new battery, and I even took the connector off the fuel pump and took a test light to see if there was any power coming into the plug and I get nothing....any ideas on this?
May 27, 2008 at 10:16 AM
  • 110,244 POSTS
Hi:
If the relay is good and you have no power to the pump, you must have a broken wire or bad ground. If you have a test light, check for power grounding the test light to a reliable ground. If there is still no power, you need to work backwards until you get power.
I'll assume the fuse is good. Also, don't make any sparks near the fuel tank!
Oct 19, 2008 at 11:06 AM
