I had this car running about a month ago, right after I changed the alternator belt....used an old battery to jump start it....let it run for about an hour, shut it off...and have not been able to start it since...I replaced the MAP sensor and Fuel Pump Relay....there is a new battery, and I even took the connector off the fuel pump and took a test light to see if there was any power coming into the plug and I get nothing....any ideas on this?
May 27, 2008 at 5:16 PM
