1994 Plymouth Acclaim Hood won't lock
1994 PLYMOUTH ACCLAIM
95,000 MILES • 4 CYL • FWD • AUTOMATIC
202TUCKER
The hood will not lock.The saftey catch works but not the locking mechanism.
Jul 13, 2008 at 12:56 AM
  • 110,244 POSTS
Hi:
Make sure the hood release cable is not damaged and is pushed in the entire way. If the cable is working properly and you've lubericated the latch mechanism I would suggest replaceing the latch assembly. I believe ther are only two bolts holding it on, and the cable is easily removed.
Oct 10, 2008 at 1:28 PM
