1994 Plymouth Acclaim Front signal bulb replacement
ZIRKOVA5
Electrical problem
1994 Plymouth Acclaim 6 cyl Front Wheel Drive Automatic
Please advise how to get at the right front signal bulb. The Harness runs up to the lamp but is obstructed by a plate that I can't seem to get around. Thanks in advance.
Sep 30, 2009 at 3:45 AM
CH112063
  • 1,320 POSTS
If you have too much trouble try unscrewing the whole lamp assembly from the front instead. It is difficult from behind to turn and pull the socket out.
OK Joe
Oct 6, 2009 at 1:56 PM
