1994 Plymouth Acclaim engine stops
REDD53
1994 Plymouth Acclaim 4 cyl Front Wheel Drive 90,000 miles
I HAVE A 94 PLYMOUTH ACCLAIM THAT WILL JUST QUITE
RUNNING SOMETIMES AFTER GOING 1 MILE SOMETIMES
25-30 MILES.LET IT SIT A FEW HOURS THEN WILL START RIGHT
UP.WE HAVE REPLACED FUEL PUMP.INLINE FUEL FILTER,
THE FUEL INJECTOR.WE CHANGED OIL AND FILTER. DO YOU HAVE
ANY SUGGESTIONS
Jun 15, 2009 at 2:03 PM
  • 110,248 POSTS
When this happens, I need you to check if it is getting spark. If it isn't, have the crank sensor checked. If it is getting spark, then there is a fuel related problem.
Let me know what you find.
Sep 25, 2009 at 3:41 AM
