1994 Plymouth Acclaim distributor pu
DAD OF 6
Engine Mechanical problem
1994 Plymouth Acclaim 4 cyl Front Wheel Drive Automatic
How do you check if distributor pickup is working coil has no spark going to it
Jul 26, 2008 at 8:36 AM
  • 110,248 POSTS
Hi:
Are you getting power to the distributor? If so, replace the pick-up. If you are not getting power, you will need to look for a broken or shorted wire to the distributor.
Oct 10, 2008 at 1:19 PM
