1993 Plymouth Acclaim radio doesn't work (no power)
106,000 MILES • 4 CYL • FWD • AUTOMATIC
WOODY14RULES
what is the fuse number for the radio
Jun 14, 2009 at 11:55 AM
CARADIODOC
  • 34,413 POSTS
There's two fuses. One will be tied to something that's hot all the time such as interior lights or horn.
What is the symptom and type of radio? If the clock display works, the fuses are good. If you have a cassette player, and the display flickers a little when you cycle the power switch, suspect burned contacts on the switch. I've repaired hundreds of those.
caradiodoc
Jun 19, 2009 at 9:39 AM
