Engine Mechanical problem
1993 Plymouth Acclaim 4 cyl Front Wheel Drive Automatic
on this 93 dodge acclaim, i have a problem that the numbers 1 and 2 cyl. missfire. after a few tests. i notice all cyl. get fuel land spark, but the 1 and 2 have 0 compression, and the 3 and 4 have between 120-125. i removed the valve cover and see the cam moves the valves correctly it seems. rings, broken or stuck valves or timing seem to be the issue, however, no compression at all in the cyls. make me lean to broken or stuck valves. any ideas?
Jan 10, 2009 at 12:48 AM
