1992 Plymouth Acclaim Radiator overheats
1992 PLYMOUTH ACCLAIM
245,000 MILES • 4 CYL • FWD • AUTOMATIC
REINHART1799
I'm wondering what else to try here, my engine heats up and the radiator fan rarely turns on (even when the heat sensor is almost at the point of the check gauges light blinking. I replaced the themostat and gasket, as well as recently replaced the head gasket, what would be the next things to try?
Jun 24, 2010 at 3:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if radiator fan(s) not coming on properly than check for faulty engine coolant temp (ECT) sensor
Jun 24, 2010 at 10:12 AM
