1992 Plymouth Acclaim Gas tank replacement
1992 PLYMOUTH ACCLAIM
84,333 MILES • 4 CYL • 2WD • AUTOMATIC
TONY61377
I looked up the price of a new gas tank,which i found. I just wanted to know what generally gets changed with a gas tank. I heard something about the "main lines." What exactly are they called and how can i get a hold of them?
Sep 29, 2009 at 1:13 AM
RACEFAN966
  • 5,029 POSTS
I would just replace the tank unless you are having a fuel pump problem then replace that too. I have not had to replace any of the fuel lines when replacing the tank. If you don't mind me asking why are you replacing the tank?
Sep 29, 2009 at 3:36 AM
TONY61377
It needs replacing because it is leaking.
Sep 29, 2009 at 5:57 AM
RACEFAN966
  • 5,029 POSTS
Thats a good reason. Well if that is the only reason you are replacing it then I would just replace the tank nothing else. Now what you can also do is tape off the holes for the fuel pump and such and use some 3m undercoating and coat it first, this will protect it from road grime and rusting.
Sep 30, 2009 at 2:44 AM
