1991 Plymouth Acclaim Wont Start - Oil Lamp Light
1991 PLYMOUTH ACCLAIM
THATISMYNOODLE
My 91 plymouth acclaim wont start, It cranks normally but just wont start.
The only code I got was 12 55, I figure this is because I removed the cables and cleaned them because they needed it badly.
Also the oil lamp light stays lit when all the other lights go off.
Jun 7, 2010 at 6:11 PM
Hi thatismynoodle, Welcome to 2carpros and TY for the donation
Disconnect the oil pressure sending unit and see what happens-let me know
11 Engine has not been cranked since battery was disconnected.
12 Memory Standby power lost.
13 MAP sensor pneumatic circuit.
14 MAP sensor electrical circuit.
15 Vehicle speed/distance sensor.
16 Loss of battery voltage sense.
17 Engine running too cool.
21 Oxygen sensor circuit.
22 Coolant temperature sensor circuit.
23 Throttle body temperature sensor circuit.
24 Throttle position sensor.
25 AIS motor driven circuit.
26 Peak injector current not reached.
27 Fault in injector driver interface circuit.
31 Purge solenoid circuit.
32 On Calif. models, EGR diagnosis.
33 A/C cutout relay circuit.
34 Speed control solenoid driver circuit.
35 Fan control relay circuit.
37 Fault in part throttle unlock solenoid driver circuit.
41 Charging system excess or no field circuit.
42 ASD relay circuit.
43 Fault in ignition coil control circuit.
44 Loss of FJ2 to logic board.
46 Battery voltage too high.
47 Battery voltage too low.
51 Oxygen feedback system stuck at lean position.
52 Oxygen feedback system stuck at rich position.
53 Internal logic module problems.
54 Indicates a fault in the distributor high data rate pickup circuit.
55 Completion of fault code display.
62 Indicates unsuccessful attempt to update EMR mileage.
63 Unsuccessful attempt to write to an EEPROM location by the controller.
77 Speed control power relay circuit
Jun 7, 2010 at 6:36 PM
