1991 Plymouth Acclaim Vibration
AZPLYMOUTH
I have a annoying problem with this vehicle. When I stop the car (i.e, at a stoplight) the entire car vibrates. This vibration stops once I remove my foot from the brake pedal. If I gently touch the brake it may not happen. The vibration only occurs in forward gears not in reverse. Also, if I place the car into Neutral the vibration will go away. Could you please tell me what could be. I have already replaced the front brakes and a bad CV axle thinking that this would fix the problem and it didn't.
Nov 25, 2006 at 4:42 AM
FUAD12
its probably an exhaust rattle, i had this problem with my '92 plymouth acclaim. after jacking it up, putting blocks under the vehicle, had someone get in, put car in gear and operated the brake.
Jun 25, 2007 at 4:49 AM
