hi, my car probably has a fuel system problem. If i use starter fluid, i can crank it, but when the fluid is over doesnt run anymore.
i check the plug in the fuel pump and it doesnt have power. i try to check the power in the fuel pump relay plug, and it supposed to have power, but i dont know how to check the power (do i need to put one terminal of the tester in one pin and the another one in ground?). if it doesnt have power, what do i need to do? there are any fuse?
thanks
thanks
Mar 7, 2010 at 11:07 AM
