1991 Plymouth Acclaim 1991 Plymouth Acclaim fuel pump rela
MADHELL
  • 1991 PLYMOUTH ACCLAIM
Other Category problem
1991 Plymouth Acclaim 6 cyl Wheel Drive Type unknown Automatic 64,537 miles
I start the car by putting the gas in the pump but when I put the rest of the gas in the tank the car will not start now I wonder may be is the relay in the car where can I find the relay in the Plymouth Acclaim.
Sunday, February 17th, 2008 AT 12:48 PM
  • 109,885 POSTS
Hi:
The relay is in the power distribution center under the hood or it could be on the inner fender under there too. If you replace it and the problem still exist, check for power to the fuel pump. The pump may be bad.
Friday, March 20th, 2009 AT 10:44 PM
