1990 Plymouth Acclaim the car has no heat
1990 PLYMOUTH ACCLAIM
TAKEN2NOTFORU
Heater problem
1990 Plymouth Acclaim 6 cyl Front Wheel Drive Automatic
i was wanting to know if u could tell me whats rong.
ive just got out of the shop from having every hting fixed on it and it is blowing white smoke out.ive had a new head gasket put on and a lot of uther work done on it.will the buffy white smoke go a way?
i also have no heat and ive checked every thing out.
the blower works realy good and everything is full.ive also checked the heater core and it also is clean and open.ive did everything that i new to check and my heater a justers are working fine too.nuthing seems to be pluged up.the car dont over heat. what do i do?and there is no leaks or smell.please help..
Apr 11, 2009 at 6:22 PM
MERLIN2021
  • 17,250 POSTS
If it's blowing white smoke, take it back to the shop! Check coolant level, that head gasket job may have been done poorly, or not at all...Or take it to a radiator shop and have them pressure test it, this will give you the ammo you need when you bring it back!
Apr 12, 2009 at 12:16 AM
TAKEN2NOTFORU
so will the puffy white smoke stop in time or should it have already?ive only had the car back 5 day's but have not run it much.
[quote:f9499c9809="merlin2021"]If it's blowing white smoke, take it back to the shop! Check coolant level, that head gasket job may have been done poorly, or not at all...Or take it to a radiator shop and have them pressure test it, this will give you the ammo you need when you bring it back![/quote:f9499c9809]
Apr 13, 2009 at 12:53 AM
MERLIN2021
  • 17,250 POSTS
Should NOT be smoking, it's not good for it's health!
Apr 13, 2009 at 7:30 AM
