Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Tucson
Ignition
Firing Order
Diagram needed for plug wire to coil the order on coil?
2005 HYUNDAI TUCSON
130,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
SHENDA REEVES
MEMBER
1 POST
I need a picture of the order of plug wire to coil the order on coil.
Sep 19, 2024 at 9:04 AM
Experienced Mechanic
Sure, here is the ignition coil wiring and the ignition system firing order. Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Sep 20, 2024 at 3:44 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
