I replaced my fuel pump after I was done I tried starting it it started but for only a few seconds then died it done that five or six times. Every time it would only run a few seconds. I have tested everything the pump is pumping all that, but now it wont do anything, all the lights gauges everything works, but my engine will not even turn over. now I have told several different things I have reset the computer everything I listened to this guy he told me the security system is on so he told me to lock all doors wait a few minutes manually unlock driver side door put key in it should start. I did that and my alarm started going off I tried hitting the button on my key they are not working. I put key in the ignition still nothing. the only way I good get it to stop is disconnect the battery a few hours later went and tried again soon as I hooked up the battery alarm starts again. so now I am stuck with it not even turning over to start. now I got an alarm that constantly goes off if the battery is hooked up and it ran just fine until fuel pump went out. I got a new one installed it I tested the pump to make sure it pumping gas shot out of it. so now it only wont turn over to start. the alarm is going off it started five or so times after I installed the new pump, but only for a short few seconds. Please help me this is my family's only vehicle.
Sep 28, 2016 at 5:49 PM
