Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Drivetrain
Transmission
Symptoms
Engage
Transmission will not engage?
1999 CHEVROLET BLAZER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
LENA_PLANK
MEMBER
1 POST
Was driving and stopped at a stop light all of a sudden vehicle does not want to go forward or backwards.
May 31, 2022 at 5:22 PM
Experienced Mechanic
It sounds like you are low on fluid. We should check the level first, this guide will help walk you through the steps:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
If the fluid level is okay, we should run the codes to see if anything comes up
and
I have seen the pressure control solenoid go out and cause this issue here is the location of the solenoid so you can check it out. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Image (Click to enlarge)
Jun 1, 2022 at 4:57 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
