Because cold air only comes out of the passenger side vents with a/c on, I'm trying to replace the left side plenum door actuator on the driver side. After removing the 3 mounting screws, the actuator seems to be hung up on the shaft. Because everything is plastic, I hesitate to pry on it too hard. Do you think there is something that I'm overlooking? Thanks
Jul 17, 2019 at 2:03 AM
