intermittent PCM power loss
106,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
ZEMORZEMOR
  • 486 POSTS
what is the voltage drop allowed for PCM powers and grounds? my PCM loses power. sometime it is intermittent and get two codes p1603 and p0882.
Sep 2, 2017 at 6:51 AM
HARRY P
  • 2,292 POSTS
Unfortunately, it appears that Chrysler has not supplied that information. At least not anywhere that I can find it. From my research, the P1603 code is the one to address. It points to an internal fault in the PCM. That fault is also probably the cause of the p0882 code (from the TCM). I am including what information that has been provided in the images below. Hope it helps.
Sep 2, 2017 at 8:23 AM
ZEMORZEMOR
  • 486 POSTS
last year the PCM was replaced because of those codes. after replacing it the only code that came back is the p0882 recently p1603 showed up. and they shows up when the weather is hot. so i think its related to heat. i did voltage drop for PCM grounds it was 25 mv however power sides were 74 mv, 255 mv, 320 mv 95 mv 79mv those are for all hot wires.
Sep 3, 2017 at 6:14 AM
HARRY P
  • 2,292 POSTS
Hmmm Honestly the best that I can tell you is that you need to start from the beginning again. I would do the test suggested in the images to see if the PCM is bad and then go from there. I'm betting on a problem with it.
Sep 3, 2017 at 7:26 AM
ZEMORZEMOR
  • 486 POSTS
I did those tests and the computer has powers and grounds.
the instruction after says check for bad connections how to do that?
i remember i have seen a video a guy used a tool like needles has different thickness and insert them in the computer females pins and check for dhow much a pin drags and compare it to the other pins. can you tell me what they call that tool please?
Sep 3, 2017 at 12:49 PM
HARRY P
  • 2,292 POSTS
That tool is a PCM pinout tool, and it costs about $300. Here is a link to one: https://www.handsontools.com/Miller-Mopar-Tools-8815-1-PCM-Pinout-Box-Adapter-_p_35916.html. Short of buying that, the best thing that you can do is to follow the wiring yourself and closely inspect it. In particular, look at the power and ground circuits. You can also use a multi-meter to check resistances along those same circuits. Excessive resistance means that there is an open circuit. Repair it and your problem should be solved. If you cannot find any problem with resistance in the wiring, then your issue is in the PCM itself.
Sep 3, 2017 at 9:26 PM
ZEMORZEMOR
  • 486 POSTS
thank you the tool i m talking about is a lot of needle it like the one dentist uses when when do a root canal. and you stick those needle in female connector and check how much drag it is. if there is no drag means the female pin is loose.
Sep 4, 2017 at 1:56 AM
HARRY P
  • 2,292 POSTS
Honestly we're a little out of my comfort area here. I'm going to phone a friend and see if we can come up with what you're referencing.
Sep 4, 2017 at 12:35 PM
HARRY P
  • 2,292 POSTS
Ok here's what I found out. What you're talking about is a Terminal test set / drag testers. Basically a set of wires with the known size of connector pin on the end. They come in handy for things like loose relay sockets, loose ECM wiring and more. Useful on the weatherpack and metripack style multi-pin connectors where one of the pins may carry a lot of current and overheated the spring tension or someone has been probing the pins with a bit of force.
https://www.aeswave.com/uTest-Advanced-Terminal-Test-Kit-p9573.html
You can make a set yourself. The way to make them is to strip a few connectors. Pick out the male pins that are clean and you have some drag test pins. You can buy lab quality ones that they use in the factories when making the connectors but those are solid metal shaped sort of like a multimeter probe. They are not field friendly because you need to be VERY careful inserting them and they are un-insulated.
This is almost word-for-word what I was told. Hope it helps you out.
Sep 5, 2017 at 7:47 AM
ZEMORZEMOR
  • 486 POSTS
thank you. so far the car is not throwing out those codes i disconnected all pcm connectors and clean them with contact cleaner and disconnected connector goes to solenoid pack, and others on transmission and clean them with the same cleaner I don t know if i can tell you the brand in this website but i heard it works very well
Sep 6, 2017 at 12:04 AM
HARRY P
  • 2,292 POSTS
Please do tell us what cleaner you used. Especially if it works.
Sep 6, 2017 at 11:26 AM
ZEMORZEMOR
  • 486 POSTS
It's called Deoxit musicians use it to fix scratchy potsit. It suppose to remove corrosion and improve contact.i saw video where mechanich use it to fix high resistance in abs connector
Sep 8, 2017 at 11:00 AM
HARRY P
  • 2,292 POSTS
Good to know. I'm going to store that little nugget of information in my head. Thanks.
Sep 8, 2017 at 11:55 AM
ZEMORZEMOR
  • 486 POSTS
here is the link of the video https://www.youtube.com/watch?v=ITBwoFq_zps&t=1s
its called " DeoxIT treatment to repair a CAN network problem (3 of 4)"
I will let you know if the codes come back hopefully not
Sep 10, 2017 at 12:59 AM
ZEMORZEMOR
  • 486 POSTS
the code p0882 is back . however p1603 is not. what you think?
Nov 7, 2017 at 9:04 AM
HARRY P
  • 2,292 POSTS
Here's your thread from a couple of years. The info is still good. https://www.2carpros.com/questions/2006-chrysler-pt-cruiser-p0882
Check the power and grounds to the pcm
Nov 8, 2017 at 5:46 AM
ZEMORZEMOR
  • 486 POSTS
I did they are good. what i think is the code comes when its hot either the weather or use the car a lot.
Nov 9, 2017 at 12:49 PM
HARRY P
  • 2,292 POSTS
Usually that means that there's some corrosion in the power circuit somewhere (either in the hot lead or the ground lead), or some other type of problem with the power or ground. There pretty much has to be something going on there. I know you did it all a while back, but since the code went away for as long as it did, you kind of have to start the diagnostic process over. It's a pain, but that's the best way to do it.
Nov 9, 2017 at 7:35 PM
ZEMORZEMOR
  • 486 POSTS
ok i will check it again plus i will do voltage drop test for the T15 circuit wire its the feed back to the pcm from the tipm
Nov 11, 2017 at 1:12 PM
ZEMORZEMOR
  • 486 POSTS
I checked powers and ground they are fine. voltage drop is around 37 mv and when radiator fan on is around 60 mv. I checked also T16 circuit the feed back to the pcm at the pcm i back probed the two red wires it has battery voltage when key on engine off. and charging voltage 14.5 when engine is running. now the check engine is off and no codes
Nov 12, 2017 at 9:56 AM
HARRY P
  • 2,292 POSTS
Sorry I just got the message. Seems like one of the wires must have a weak connection. Whatever you did might've tightened up or just gotten into a good position temporarily. Cross your fingers and hope the code stays away
Nov 13, 2017 at 9:09 PM
ZEMORZEMOR
  • 486 POSTS
I guess to check for a weak connection have to wiggle the wires which i did. also i removed wires from there connector and tighten them . but i did not do the ones goes to pcm i do not how to depin the two red wires aka the feed backs
Nov 15, 2017 at 1:31 PM
HARRY P
  • 2,292 POSTS
Well it pretty much has to be either the wiring or the PCM itself, unless I'm missing something. Are there any other fault codes?
Nov 18, 2017 at 1:04 PM
ZEMORZEMOR
  • 486 POSTS
p0700 and once long time ago p1603 but did not come back again
Nov 20, 2017 at 5:45 AM
HARRY P
  • 2,292 POSTS
Ok. I was thinking that the P0700 was a low power code, but it's not. It's simply indicating that there's a transmission code stored in the Transmission Control Module (TCM) . You'll need to get it scanned, probably at a transmission shop or at the dealer. Do that, and we'll go from there.
Nov 20, 2017 at 8:35 PM
ZEMORZEMOR
  • 486 POSTS
I checked again today the only code is p0633 key is not programmed it always been there since i replaced the pcm. no p0700 or p0882
Nov 21, 2017 at 5:10 AM
HARRY P
  • 2,292 POSTS
Attached below is AllData's information on P0633. Basically, it says to get the key programmed. If that doesn't do it, then replace the PCM. Since you've already replaced it, I'd try getting it reprogrammed first.
Nov 21, 2017 at 11:17 AM
ZEMORZEMOR
  • 486 POSTS
so do you think the cause of p0882 is because the key is not programmed in the pcm . ?
Nov 21, 2017 at 11:23 AM
HARRY P
  • 2,292 POSTS
633 is the only code right now. I wouldn't worry about one that you don't have currently. Fix the issue causing the 633 code, and it might take care of the other intermittent stuff. Basically, address the problem that you know you have.
Nov 21, 2017 at 11:31 AM
ZEMORZEMOR
  • 486 POSTS
The code is back p0882 and p700 .the code triggered when starting the engine . i read the freeze frame data the pids are
engine run time 12 seconds
Tps 0
Vpwr 14.005
Baro HG 25.4
vehicle speed 0
engine speed 722
Map 12
the outside temp was 47F
Nov 25, 2017 at 3:15 AM
HARRY P
  • 2,292 POSTS
P0700 points to the TCM, saying that there's a code stored in there. The P0882 also points to an issue with the TCM, or that there's a code stored in there. Get it scanned at the dealership or a transmission shop to see what's going on.
Nov 26, 2017 at 11:02 AM
ZEMORZEMOR
  • 486 POSTS
I forgot to mention the ignition switch actuator is bad . i did not find where to get the part. to let you know what i m talking about please watch this video found on YouTube
2007 2008 PT Cruiser Ignition Actuator Disassembly
Nov 26, 2017 at 12:03 PM
HARRY P
  • 2,292 POSTS
I'd stick with getting it scanned first. As for the actuator, someone has to have it for sale. The dealer, AutoZone, Advance Auto, NAPA, O'reilly, someone has to have it.
Nov 26, 2017 at 12:39 PM
