Please solutions to the below codes:
U0006
U0010
U0018
U0019
Jul 2, 2018 at 2:05 AM
✓Experienced Mechanic
These are network codes. Can you tell me more of what is happening? What works what does not? Does the car run?
Please let me know,
Cheers, Ken
Jul 3, 2018 at 6:26 AM
FRIMAT
MEMBER
The engine runs only when a fluid is sprayed in the air-hose. And the engine does not run for long.
Jul 3, 2018 at 7:41 AM
Yes, it sounds like the PCM has gone out and needs to be replaced. Remove the PCM and look for water damage. Then replace it with a used one to see what happens.
