humming from the front of vehicle
116,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ELEMELLE
Once i get between 30 and 40 miles it starts humming from the front of vehicle, at one time it stalled the gears wasn't shifting. I had to wait about 20 minutes and it was okay, 40 it gets a little hesitant, I can drive it, no problems starting at all just over a certain speed it sounds like humming.
When I'm low on brake fluid and i turn left the traction light comes on and it makes a cranking sound
Sep 18, 2014 at 4:52 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked your tires yet tread separation cupping etc?Next I Would check your front wheel bearings. Do you Have a floor jack and jack stands?Also any codes in the computer have you checked for codes yet?
Sep 18, 2014 at 6:02 AM
ELEMELLE
Will that cause it to stall as well because my check engine light is on .....my do you think it could be my transmission
Sep 19, 2014 at 12:20 AM
ELEMELLE
Havent checked tires seperation.....just purchased two used tires about a month ago and two more two months before that
Sep 19, 2014 at 12:21 AM
SATURNTECH9
  • 30,869 POSTS
If you could get your car scanned for codes and let me know the exact code numbers not code descriptions? I could you alot more thats the first thing I would do if I had the car in front of me. A free code scan at the auto parts store will do for now. But it might take a professional scan tool that can read every computer to diagnose the problem.
Sep 19, 2014 at 2:51 AM
