I need the main bearing and big end torque setting.
May 18, 2019 at 6:51 AM
STEVE W.
✓Experienced Mechanic
Hello and welcome to 2CarPros. From the information I can find on that car and the 1.4 engine the main bearing cap torque is 54-59 Nm or 40-44 ft.lb. Rod bearing torque numbers are 31.5 - 34 Nm or 23-25 ft.lb. Hope that helps.
May 19, 2019 at 12:43 PM
COOLIOMYR
MEMBER
Thank you very much.
May 20, 2019 at 5:16 AM
STEVE W.
You are welcome, please return anytime with your automotive questions.
