Will not start after the engine overheated?
100,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
SAVAGENTAVERAGE
Overheated and blew out a little smoke then shut off and won't start now... I know the water pump needs to be replaced but what else is wrong? why won't it start a how can I fix/repair it at minimum cost?
Oct 20, 2022 at 11:53 PM
  • 55,711 POSTS
If the engine was extremely overheated you may have lost compression which means the engine will need to be replaced, if you can upload a short video of the engine cranking over, I can tell you for sure.
You can also do a compression test to confirm the damage.
And this guide may help as well:
https://www.2carpros.com/articles/car-not-running-advanced
Let us know what happens and please upload pictures or videos of the problem.
Oct 21, 2022 at 3:39 AM
