Car Repair Question
4,200 MILES • 0.6L • 4 CYL • 2WD • AUTOMATIC
COURTNEY MILLER
I have a 96 Saturn SL2 and its starting to misfire (sometimes) and its starting to smoke and has recently having high idle and I dont want to waste money on guessing the problems any clues would greatly br appreciated
Sep 9, 2016 at 1:04 AM
COURTNEY MILLER
I have put in a new fuel filter but it actually is starting to sputter all the time now
Jan 22, 2019 at 3:37 AM
SATURNTECH9
  • 30,869 POSTS
I would start by looking at the plugs and wires and inspect the coil towers for corrosion.Also you could have a vacuum leak causing the high idle or a egr valve that's sticking causing the high idle and rough running.Have you checked for codes in the computer yet?
