Engine knock when idling
190,967 MILES • 6 CYL • 2WD • AUTOMATIC
AIMEEMECHELLE
  • 6 POSTS
Can has a knock only when idling and leaking something black under the van. blows white smoke muffler is melting the back bumper.
May 16, 2019 at 2:11 PM
SCGRANTURISMO
  • 4,897 POSTS
If your vehicle is blowing white smoke and it has a sweet smell to it than this is probably going to be coolant that is getting burned up in the combustion process of your vehicle's engine. The black stuff leaking underneath your vehicle will undoubtedly be oil, and if the muffler is melting the bumper then something has bent the exhaust up so that it is probably touching the bumper and will need to bent back down so it is not touching the bumper. I have included a few links for you to go to below:
https://www.2carpros.com/articles/engine-noises
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
https://www.2carpros.com/articles/engine-is-leaking-oil
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 16, 2019 at 2:38 PM
